front discs
front discs
due to the pain,the lack of grip and an impending op to to kill my right hand i'm looking into swapping the controls(brake lever) from the right bar to the left but before i splash out £1000+ that i don't really have for a dual lever system i thought i'd a question about an option i've been given.
i was told i could run a single front disc and link it to the rear brake lever and use a brake bias adjuster thats commonly used on rally/sprint cars..
will a single disc be enough to brake effectivly/safely?
will it pull to one side when braking?
would i be better keeping twin disc setup and upgrading to CBR calipers and linking them then linking into the rear,i think the blackbird uses this configuration
thanks
thanks
Re: front discs
You should get in touch with these people NAPD http://www.nabd.org.uk/index.htm as they may be able to suggest some kind of set up that may be of use to you.
Re: front discs
You could just use one disc and it wouldn't pull to one side .
The down side is you will have a lot less braking force to stop the bike .and that would be even more so if you only use a rear brake master cylinder and link the front and rear as the rear m/c is small and not meant to operate the front brakes .
How about swapping the front brake and clutch over . The clutch is a smaller m/c but if its only operating one calliper it might be ok .
- scott02464
Re: front discs
Doesn't the vfr have a dual braking system (it does :-)) could you not adopt it to suit yours mate?
Re: front discs
It does. It would a complex system to set up on a vtr though. But it don't solve his problem of having to squeeze the brake with his hand.Doesn't the vfr have a dual braking system
I may be wrong but I think on the vfr if you apply pressure to the rear brake the larger percentage of pressure gets applied to the rear with little on the front. Don't now the exact percentages but something like 70 rear 30 front. Where as if you only pulled the front brake it is reversed with more on the front with a little rear.
- scott02464
Re: front discs
I see, I would be handy (excuse the pun) to have the brake peddle on the right foot but front biased, as if the foot peddle directly replaces the right hand lever, if that makes sense?
Re: front discs
carl..i've looked on the NABD website and i could get the adaption(dual levers) through their grant system but doesn't guarantee i'll get it.
i have thought about moving the rear brake onto a bar mounted thumb break and finding a larger mc for the rear peddle and using it solely to operate the front breaks but as yet i haven't found any specs so i can compare rear mc's to front mc's to get as close a match as i can,maybe it's me not looking in the right places though
more searching needed i think
Re: front discs
They're "brakes" by the way. "Break" is when something's just broken ;).
There's spec for the front master cylinder in the workshop section.
What if you put just a massive master cylinder on the front so that you didn't need to squeeze that hard to make them move?
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
'94 KTM LC4 400e
Re: front discs
that would be a smaller master cyl that you need to reduce the force, a big one just moves more fluid but at a lower pressure...... CBR600F4 calipers [they have a bigger piston area] with a standard master cyl will give you that effect and stronger brakes so you get a double benifit. The down side is the lever travel will be longer.Xenocide wrote:What if you put just a massive master cylinder on the front so that you didn't need to squeeze that hard to make them move?
The std front master cyl is a 14mm diameter and i think the rear is about the same, so it might be possible to run the fronts off the back, but the pedal travel will be at least 5 times longer to move enough fluid to make all the pistons move.
Re: front discs
There endith our English lesson for today. Now go to the back of the class and write "though shall not break my brake" 500 times.They're "brakes" by the way. "Break" is when something's just broken ;).
Re: front discs
Or say out loud 50 times, without a mistake:-
A bloke's back brake block broke.
BTW it's endeth.
BTW it's endeth.
'02 VTR1000-FY Yellow.
Re: front discs
thanks for the English lesson but typing with my left hand when i'm right handed is still alien,give it a try..
am i right in thinking that a smaller rear mc would give me less pedal travel but would a smaller mc have enough pressure to operate both front calipers.
Re: front discs
A larger master cyl would be needed to move more fluid and to make less pedal travel,.
Good news is you can apply more force with your foot than your hand, but bad news is you have less feel so you need to get the balance right.
Or fit a servo
Or fit a servo
Re: front discs
Power assisted brakes I like it.Or fit a servo
Re: front discs
I wonder if you can swap to the blackbird linked setup fairly easily?
There's enough BB owners de-linking their brakes, so maybe a swap over could be arranged......
Not sure what parts you'd need to swap, though.
