Can any one tell me what i need to do with the yellow one please
And in a way a wombles like me will understand
Cheerscybercarl wrote:OK I am trying to be logical about this. Black is obviously the earth going by the colour and it has a ring terminal. The Red and Yellow are both fused which suggests they are both live, so Red I would have thought is a permanent and the Yellow is either an accessory feed or it goes to the switch. I asked this in the other thread, but what's on the other end by the connector block. What does it connect too? Does it come with it's own switch? You obviously have the led to let you now it's switched on. If the yellow is an accessory then you could join it to the Red and connect them both to the battery to test if it works. This would give you a permanent feed so will work with the ignition off. But that is all just guesswork. Mmmm It looks like it draws some serious power as those cables on the lights themselves are massive.
Red button, I thought that was an led warning to say when they are switched onThe switch is the one with the red botton
That's Bondage Squirrel.cybercarl wrote:
What's the Grey wrapped up in electrical tape?
When the going get's tough, the tough say "ferk it I can pay a guy!"
