Sp1/sp2 rear shock
thumperslaw
Sp1/sp2 rear shock
Post by thumperslaw »
Why would they not fit the firestorm
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Re: Sp1/sp2 rear shock
Cos they be of different length...
http://www.superhawkforum.com/forums/te ... post209006
[QUOTE=JamieDaugherty;209006]An RC51 shock won't work because not only is not the correct length it's also got a WAY too light spring and valving. There isn't anything that just bolts on, sorry. I know, I sometimes find myself searching for that holy grail part from something else that you can buy for $20, is a direct bolt-on and has the performance and features of aftermarket shock. However, when I return to reality I find that it takes a little bit more work than that.[/QUOTE]
thumperslaw
Do we know by how much?
K100 "flying brick"
Quite a lot, and the linkage ratios are also very different, so the shock wouldn't work well without an awful lot of cutting and shutting.
Stick it back on Ebay....
:lol:
thumperslaw
tony.mon wrote:Quite a lot, and the linkage ratios are also very different, so the shock wouldn't work well without an awful lot of cutting and shutting.
:lol:
Just brought standard firestorm shock.
Just wanting to know that's all
K100 "flying brick"
