Ht lead upgrade
thumperslaw
Ht lead upgrade
Post by thumperslaw »
Any one done it? Like Taylor leads or any one tried running dyna coils or dyna 2000 set up
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Stratman
Re: Ht lead upgrade
Post by Stratman »
I didn't think that you could replace just the leads?
Re: Ht lead upgrade
I thought the same as Paul (Stratman), isn't the ht lead at the coil end built in to the coil housing?
Re: Ht lead upgrade
Nothing to stop you fitting coils with ones with leads that screw on.
However, just like connecting lots of 1m leads together to connect a tv aerial or connecting phono leads together to connect a cd player, the losses through the joins are more than the saving by using good oxygen-free copper or silver HT leads.
However the screw connection at HT lead/cap joint can be cut back by 6mm or so and reconnected. Make sure that you have enough spare slack length before you cut any off, though.... :eek2
