Got a wee engine thingy for Xmas and decided to share it with you lot, seeing as Im a sad old b8stard. :q38:
had to put the pistons together
Then attached them all to the crankshaft.
Pistons were then inserted into the block
Sump and a wee stand were attached.
Inlet valves and exhaust valves had springs fitted (lost one and spent about half an hour looking for the b8stard)
Valves fitted into cylinder head.
Rocker arms ready to be attached to the head.
fitted in place
Cylinder head gasket fitted to block
top end and bottom end joined together
Cams fitted to cam shaft
installed
rocker cover added
setting up the timing using a supplied tool.
timing belt and cover fitted
Pullies added
fan and fan belt
distributor fitted and timed to piston 4 tdc
God I hate bloody wiring
inlet manifold
finished thank feck
Didny even get dirty hands.
