stopper mod
stopper mod
HI all going to tackle the stopper mod and this might be a stupid question but how do i work out what length of rod i need ,any help would be great
Re: stopper mod
A micrometer is the what I used, where it has a pointy bit that can go inside and get an exact measurement. Otherwise you will need to come up with another solution like putting a long nail or screw inside and making a score mark on it. Or you could just grind/cut a bit of the 8mm bar or whatever you are using as a stopper, a bit at a time until it fits snug and you can put the roll pin back in the end bit.
Have good read through the stop mod http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=19416
and how to set the timing http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326
Re: stopper mod
I use a cheap digital vernier caliper, but you can use a steel rule if you stick the 8mm bar into the CCT and measure ho much is sticking out.
Re: stopper mod
That's what I mean not Micrometer (just slapping myself around the headvernier caliper
One of the most useful tools I have bought
You can get them cheap enough on ebay.
http://www.ebay.co.uk/itm/6-150MM-DIGIT ... 27cc0e5add
Re: stopper mod
Lay in some spare batteries, though, as cold and damp do them in really quickly unless you have a heated garage.
But you can pick up 10 batteries for £4, so just keep a load ready to hand.
Re: stopper mod
Easy to remember if you connect it to a brake calipercybercarl wrote:That's what I mean not Micrometer (just slapping myself around the headvernier caliper) I always get the names of those two mixed up
Great info, btw
You never see a motorcycle parked in front of a psychiatrists for psycho therapy. All I need is cycle therapy
- benny hedges
Re: stopper mod
i use mine for setting my chain tension and alignment too - gets it bob onAMCQ46 wrote:I use a cheap digital vernier caliper, but you can use a steel rule if you stick the 8mm bar into the CCT and measure ho much is sticking out.
Re: stopper mod
Me too ! My misses bought me mine from aldi.benny hedges wrote:i use mine for setting my chain tension and alignment too - gets it bob onAMCQ46 wrote:I use a cheap digital vernier caliper, but you can use a steel rule if you stick the 8mm bar into the CCT and measure ho much is sticking out.
http://lincsrideouts.co.uk
