Help! - Feed for Heated Grips Relay
mr.john.coates
Post by mr.john.coates »
I'm finishing off my heated grips. I hate all the mess around your battery when you add accessories so I've mounted the connectors, relay and control unit inside the seat fairing (where there is loads of useful space) at the side of the starter relay and I'm pleased you can see none if it!
My last issue is where to power the new relay from so it only comes on with the ignition. I'm not brilliant with electrics, but could I use the supply to the starter relay as my new one is right at the side? I've also found the supply for the rear brake light, the indicator relay and a whole bunch of wires at the rear of the seat that might do, too, but they're not so close.
Where is best to take a supply from?
J
NT650V in Red
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
Stratman
Re: Help! - Feed for Heated Grips Relay
Post by Stratman »
Assuming you ride "lights on" how about the rear light?
alternative_vtr
Post by alternative_vtr »
I used the brake light feed on mine :)
KTM Duke 690ABS in White
alternative_vtr wrote:I used the brake light feed on mine :)
but wouldnt they only come on when your braking :!:
the rear light would be better :lol:
alternative_vtr
They are all the time when ignition is on, it was the feed to the brake light switch that I tapped into.
yeh rear brake light switch live is best imo as its conveniently close to the battery and always on with ignition.
get yourself one of these - http://www.ebay.co.uk/itm/400094914559? ... 1438.l2649
saves a lot of messin - you can then use the live to feed all your accessories :thumbup:
mr.john.coates
alternative_vtr wrote:They are all the time when ignition is on, it was the feed to the brake light switch that I tapped into.
Ah, would that be a live from that connector near the battery? the white 2-wire one?
Where did you then earth your relay to?
NT650V in Red
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
mr.john.coates
benny hedges wrote:yeh rear brake light switch live is best imo as its conveniently close to the battery and always on with ignition.
Looks good - might be tempted :D
NT650V in Red
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
alternative_vtr
Connected earth straight to negative battery terminal.
same, i use the +ve feed for the rear brake light switch as its right beside the battery
