clutch plates ?
clutch plates ?
i have my clutch out and measured the plates as it was slipping at high revs .
friction plates 3.8mm in service limit :D
steel plates 1.9mm how ever i cant find the service limits in the manual 8O
springs 47.5mm in service limit :D
my question is what is the size and service limit of the steel plates ?
Re: clutch plates ?
I don't think there are any service limits as such. Just check to make sure they are not warped or have any Blueing on the surface. :thumbup:
Re: clutch plates ?
No bluing :-) just Golding .
Think I will just stick them back in with new oil and see if it still slips !
popkat
Re: clutch plates ?
Post by popkat »
If the plates are all ok then stick some new springs in, regardless of measurements they will be weaker than when new. And they're cheap :thumbup:
Re: clutch plates ?
Try uprated springs, you can't feel any difference at the lever.
Re: clutch plates ?
Ok where do I get them from ?
popkat
Re: clutch plates ?
Post by popkat »
A Honda dealer for std ones, which should be good enough, or EBC do H/D springs for most bikes.
EBC springs
http://www.ebay.co.uk/itm/Honda-VTR-100 ... 20bec70281
Re: clutch plates ?
Thanks :thumb up:
