Presenting the inspiration for my latest project:
Not sure what you gents think but I love the tidy look of the rear brake master set-up on this bike. So, it being winter in Canada, and my brain being afflicted with OCMD, I am inspired to try something similar.
The MC on the picture comes from a Honda CRF motocross bike. Regrettably, it uses a small 3/8" piston (about 9.5mm), much too small for the VTR which uses a 14mm piston OEM. After doing some "rootin' around", I noticed that the similar Nissin units used on RM-Z and KX bikes use a significantly larger 1/2" piston (12.7mm), which is much closer size-wise to the VTR unit. In fact, I figure it's close enough to try a swap.
I picked one up cheap on eBay and will see if the mounting holes line up when it gets here (if not, it will be going back up for sale). If it does, I will replacing the banjo with a pressure switch unit to tidy up the wiring (as on the picture). I will also be looking for a "blingy" anodized cover (blue) to finish it off.
Will keep you posted
