i have searched already and found great info, and links (on and offsite ) in this thread , : http://vtr1000.org/phpBB3/viewtopic.php?f=31&t=14214
i dont want to choke that thread up with loads of posts as its staying fairly specific
so any informed help with a couple of questions would be appreciated (especially if youve posted already
bike set up , theres a dynojet sticker on it
i had planned to do the tps mod , but wanted to run the bike on the dyno first to see whats going on with the fuelling , hopefully do the lot together ,
the bike is fuelling fine on the main jet , the needle is slightly lean
but the idle circuit is very lean , this explains 1/8 1/4 throttle ''stall''/ ''delay'' i am having .
1. so...... my bikes a 97 , and it seems first models were fitted with 45 pilots and later models 48 , im guessing that i will get a better base to work from replacing the pilots to 48;s rather than trying to ''dial out'' the leaness on the fuel screw (always called the air mix screw)
2. anyone have an idea where changing the pilots would leave me in relation to the fuel screw setting , e.g. at that point would i be likely to be rich or lean?
3. i know the fuel screw settings are 3 out f , and 2 3/4 out r ,but is that for both set ups ,, 45 pilot and 48 pilot equipped machines ?
any input anyone?? mucho appreciated
