electrical work
electrical work
Hi, i think this has probably been asked before but can't find the answer at the moment, when working on the electrical system and taking parts off should i disconnect the battery or take the main fuse out? or both? thanks for any replies.
Re: electrical work
Always best to remove the battery .
Re: electrical work
Ok thanks for that advice.
Re: electrical work
Depends on what you are doing. You may want battery power if testing for lives and earth's (+ & -). If your cutting wires and there is a risk of a wire touching the frame or something and shorting out, then just disconnect the battery earth.
Re: electrical work
I was thinking about changing the R/R as my bike has the non finned one, that sort of thing.
Re: electrical work
Well disconnect the earth then, until your ready to stick a multimeter on and test the output.
http://vtr1000f.wickidnet.com/
Re: electrical work
Thanks, appreciate your help, and for the link.
