Page 1 of 2
Wheel swap time
Posted: Thu Feb 28, 2013 4:32 pm
by thumperslaw
Just got rear and waiting on front.
Will be changing bearing and having some paint on them
look better also!
Re: Wheel swap time
Posted: Fri Mar 01, 2013 12:51 pm
by thumperslaw
Front on it's way then it's off to the place of all things black
Re: Wheel swap time
Posted: Fri Mar 01, 2013 2:26 pm
by Z28DUNC
Does the rear sprocket off the storm wheel fit the blade one, what about the disc?
Re: Wheel swap time
Posted: Fri Mar 01, 2013 2:56 pm
by thumperslaw
Don't know yet
Am planing in running my drive off the storm.
Rear discs fits
Re: Wheel swap time
Posted: Fri Mar 01, 2013 2:58 pm
by lloydie
Yes all the same :-)
Re: Wheel swap time
Posted: Fri Mar 01, 2013 3:00 pm
by Z28DUNC
Spindles the same size then? Be interested how easy the blade rear is to fit. Might be a easy mod.
Re: Wheel swap time
Posted: Fri Mar 01, 2013 3:21 pm
by lloydie
Use the storms spindle as the blade one is longer .
Re: Wheel swap time
Posted: Fri Mar 01, 2013 3:23 pm
by thumperslaw
lloydiecbr wrote:Use the storms spindle as the blade one is longer .
Yep got that all planned out and I am using storm spacers
Failing that I can knock my own spacers up on the lathe
Re: Wheel swap time
Posted: Fri Mar 01, 2013 4:12 pm
by seb421
thumperslaw wrote:Just got rear and waiting on front.
look better also!
These are heavier aren't they than the stock wheel
Re: Wheel swap time
Posted: Fri Mar 01, 2013 4:37 pm
by thumperslaw
seb421 wrote:thumperslaw wrote:Just got rear and waiting on front.
look better also!
17kg with sprocket and tyre
Even if they are heavier i don't care they look better
Re: Wheel swap time
Posted: Fri Mar 01, 2013 9:10 pm
by tony.mon
I weighed mine when I fitted them- weighed the old wheel/tyre and then swapped the same tyre onto the new six- and it was lighter.
No-one seemed to believe me when I reported this on Superhawk forum, so perhaps you could do the same check?
Re: Wheel swap time
Posted: Fri Mar 01, 2013 9:37 pm
by thumperslaw
tony.mon wrote:I weighed mine when I fitted them- weighed the old wheel/tyre and then swapped the same tyre onto the new six- and it was lighter.
I'd weigh all wheels with no tyres or discs on them. Even if they are lighter it's not by much
Re: Wheel swap time
Posted: Fri Mar 01, 2013 9:39 pm
by thumperslaw
Front wheel I've got coming
This is not a blade wheel but its dam close to the rear. When they black you would never know.
It was cheaper then the blade wheel to!
Think it's vfr750
Re: Wheel swap time
Posted: Wed Mar 06, 2013 7:13 am
by hellride
I want six-spokes too...
Re: Wheel swap time
Posted: Wed Mar 06, 2013 9:26 am
by Golgother
Hey All
Any good condition Storm wheels up for grab ?
Matt
