thumperslaw
Posts: 1209 Joined: Thu Nov 24, 2011 7:14 pm
Post
by thumperslaw » Thu Feb 28, 2013 4:32 pm
Just got rear and waiting on front.
Will be changing bearing and having some paint on them
look better also!
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
thumperslaw
Post
by thumperslaw » Fri Mar 01, 2013 12:51 pm
Front on it's way then it's off to the place of all things black
K100 "flying brick"
Z28DUNC
Posts: 227 Joined: Mon Jan 16, 2012 2:51 pm
Post
by Z28DUNC » Fri Mar 01, 2013 2:26 pm
Does the rear sprocket off the storm wheel fit the blade one, what about the disc?
thumperslaw
Post
by thumperslaw » Fri Mar 01, 2013 2:56 pm
Don't know yet
Am planing in running my drive off the storm.
Rear discs fits
K100 "flying brick"
Posts: 20923 Joined: Mon Jan 17, 2011 11:16 pm
Post
by lloydie » Fri Mar 01, 2013 2:58 pm
Yes all the same :-)
Z28DUNC
Post
by Z28DUNC » Fri Mar 01, 2013 3:00 pm
Spindles the same size then? Be interested how easy the blade rear is to fit. Might be a easy mod.
Post
by lloydie » Fri Mar 01, 2013 3:21 pm
Use the storms spindle as the blade one is longer .
thumperslaw
Post
by thumperslaw » Fri Mar 01, 2013 3:23 pm
lloydiecbr wrote: Use the storms spindle as the blade one is longer .
Yep got that all planned out and I am using storm spacers
Failing that I can knock my own spacers up on the lathe
K100 "flying brick"
seb421
Posts: 4840 Joined: Fri Mar 06, 2009 1:06 am
Post
by seb421 » Fri Mar 01, 2013 4:12 pm
thumperslaw wrote: Just got rear and waiting on front.
look better also!
These are heavier aren't they than the stock wheel
thumperslaw
Post
by thumperslaw » Fri Mar 01, 2013 4:37 pm
seb421 wrote: thumperslaw wrote: Just got rear and waiting on front.
look better also!
17kg with sprocket and tyre
Even if they are heavier i don't care they look better
K100 "flying brick"
Posts: 16022 Joined: Wed Jul 25, 2007 10:46 pm
Post
by tony.mon » Fri Mar 01, 2013 9:10 pm
I weighed mine when I fitted them- weighed the old wheel/tyre and then swapped the same tyre onto the new six- and it was lighter.
No-one seemed to believe me when I reported this on Superhawk forum, so perhaps you could do the same check?
thumperslaw
Post
by thumperslaw » Fri Mar 01, 2013 9:37 pm
tony.mon wrote: I weighed mine when I fitted them- weighed the old wheel/tyre and then swapped the same tyre onto the new six- and it was lighter.
I'd weigh all wheels with no tyres or discs on them. Even if they are lighter it's not by much
K100 "flying brick"
thumperslaw
Post
by thumperslaw » Fri Mar 01, 2013 9:39 pm
Front wheel I've got coming
This is not a blade wheel but its dam close to the rear. When they black you would never know.
It was cheaper then the blade wheel to!
Think it's vfr750
K100 "flying brick"
hellride
Posts: 87 Joined: Sat Sep 24, 2011 12:10 pm
Post
by hellride » Wed Mar 06, 2013 7:13 am
I want six-spokes too...
Oh, well!! Could've been worse...
Golgother
Posts: 39 Joined: Wed Oct 31, 2012 12:44 pm
Post
by Golgother » Wed Mar 06, 2013 9:26 am
Hey All
Any good condition Storm wheels up for grab ?
Matt
1998 VTR, One of the red fast ones, Harris Laverda
