Wheel swap time
thumperslaw
Wheel swap time
Post by thumperslaw »
Just got rear and waiting on front.
Will be changing bearing and having some paint on them :) look better also!
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
thumperslaw
Re: Wheel swap time
Front on it's way then it's off to the place of all things black
K100 "flying brick"
Z28DUNC
Re: Wheel swap time
Post by Z28DUNC »
Does the rear sprocket off the storm wheel fit the blade one, what about the disc?
thumperslaw
Re: Wheel swap time
Don't know yet
Am planing in running my drive off the storm.
Rear discs fits
K100 "flying brick"
Re: Wheel swap time
Yes all the same :-)
Z28DUNC
Re: Wheel swap time
Post by Z28DUNC »
Spindles the same size then? Be interested how easy the blade rear is to fit. Might be a easy mod.
Re: Wheel swap time
Use the storms spindle as the blade one is longer .
thumperslaw
Re: Wheel swap time
lloydiecbr wrote:Use the storms spindle as the blade one is longer .
Yep got that all planned out and I am using storm spacers
Failing that I can knock my own spacers up on the lathe
K100 "flying brick"
seb421
Re: Wheel swap time
Post by seb421 »
thumperslaw wrote:Just got rear and waiting on front.
These are heavier aren't they than the stock wheel
thumperslaw
Re: Wheel swap time
17kg with sprocket and tyre :)
Even if they are heavier i don't care they look better 8)
K100 "flying brick"
Re: Wheel swap time
I weighed mine when I fitted them- weighed the old wheel/tyre and then swapped the same tyre onto the new six- and it was lighter.
No-one seemed to believe me when I reported this on Superhawk forum, so perhaps you could do the same check?
thumperslaw
Re: Wheel swap time
tony.mon wrote:I weighed mine when I fitted them- weighed the old wheel/tyre and then swapped the same tyre onto the new six- and it was lighter.
I'd weigh all wheels with no tyres or discs on them. Even if they are lighter it's not by much
K100 "flying brick"
thumperslaw
Re: Wheel swap time
Front wheel I've got coming
This is not a blade wheel but its dam close to the rear. When they black you would never know.
It was cheaper then the blade wheel to!
Think it's vfr750
K100 "flying brick"
hellride
Re: Wheel swap time
Post by hellride »
I want six-spokes too... :beer:
Oh, well!! Could've been worse...
Golgother
Re: Wheel swap time
Post by Golgother »
Hey All
Any good condition Storm wheels up for grab ? :wink:
Matt
1998 VTR, One of the red fast ones, Harris Laverda
