Fitting a Loobman
Fitting a Loobman
Was asked for some pictures of how I fitted the Loobman oiler, so here are a few pictures
Reservoir mounting kit is stuck on the side of the battery box with double sided tape and the reservoir is then cable tied into that.
Needed to push a tapered block of wood under the zigzag wire frame to fill the hollow in the swingarm and pull the cable toe tight.
Chain looks dry as I forgot to press the button on the last 50 miles of Sundays run and it was clearly very dusty with both salt and dirt out of the fields
