mccts
carmanbikes
mccts
Post by carmanbikes »
Hi All and thanks to everyone who has took time out to answer my questions,So here we go again,when replacing the original Honda ccts with the krieger manual ones do you have to take the black end cap off the honda one and put it on the krieger manual one,Its the black end cap that goes to the cam chain tensioner, :( :) :)
seb421
Re: mccts
Post by seb421 »
I didn't with my APE's been fine for 30 thousand miles use on them
Re: mccts
Are you talking about the cap on the inside end of the Honda ones held on by the roll pin :confused If so, most certainly not. The manuals will tighten up against the tensioner blade which puts the pressure on the chain. You can just set you timing, remove the old Honda ones without locking off and replace with the manuals.
When undoing the old Honda ones, alternate between each bolt an undo a bit at a time so it comes out squarely. Before undoing the bolts completely, give the end of the Honda cct a tap with a hammer or something to break the seal where it's stuck to the gasket and then remove the rest of the bolts. :thumbup:
seb421
Re: mccts
Post by seb421 »
There is that cap you can pull off the End Carl and slip over a replacement iirc, I think this is what he's talking about
Re: mccts
seb421 wrote:There is that cap you can pull off the End Carl and slip over a replacement iirc, I think this is what he's talking about
if you buy new oem tensioners from honda or silvers etc, they will not have the end cap in place so you will need to keep the old ones and fit them to the new tensioners (if you decide to fit originals)
with a new roll pin!
you dont need to fit this end cap with manual tensioners.
the tensioner does not touch the chain - there is a plate on the chain guide where the tensioner applies tension - as in this decapitated view!
bigtwinthing
Re: mccts
Post by bigtwinthing »
Yep just done that to mine and they seem to be working a treat. Piece of mind to know there fitted at last.
chrisnic
Re: mccts
Post by chrisnic »
Great....I was just about to ask the same question regarding the black end caps.
