Smokinjoe73 wrote:Lloydie, good info but I am having trouble translating, is the last one where you list the mods what you believe to be optimum?
Is it possible to write it out, like, 1st run; stock this & that, modded this & that; 1xx hp, 6x torque
How do you think rideability has changed. I find peak hp usually detracts from normal riding.
Thanks for all the good info, and mezmorizing avitar/sig video.
The last one is parts and settings used .
I just wanted to get it as rideable as I can and it rides the best I've ever had it set up like this .
These carb setting work on mine and are a very good base line for tweaking and are by no means optimal .
And I have no idea of what dose what
But I'm starting to learn what don't work .
And it will all change again in a week or two as I'm fitting either my quill cans or the akrapovic cans I bought today
