cleaning a small rusty fuel tank?
hello all. the questions in the title, i mean the inside of the tank.
i have read that you can put a handfull of nuts (off bolts) in with either petrol or kerosine and give it a good shaking? ? what do you reckon. i guess i would go with petrol option?
also if i get a load of crap out and think its ok would you just leave it or are you supposed to "treat" the inside in some way or other?
cheers
cheers
Re: cleaning a small rusty fuel tank?
It depends on how bad it is really. Don't forget you have the filter inside the tank to prevent rust getting down into your carbs. But too much crap on the filter will affect the fuel flow. I'm not sure about putting nuts or bolts inside the tank you could have a hell of a time getting them back out even with a bendy magnetic pick up tool. I would use a treatment of some kind. Not sure what though, there is so much choice on the market and I don't have much experience with rust treatment for fuel tanks.
- agentpineapple
i'm confused
if you want to clean the inside of a petrol tank, and you want to use petrol, but surely petrol was in it in the first place and that didn't stop it from becoming rusty????
for nuts and bolts i've used a tub filled with wd40 liquid, not the cheapest option but it works very well, also use an old tooth brush, as for the inside of a fuel tank, i wouldn't know where to start, i'm sure there will be a special product on the market for the job. the hardest thing is to fully empty a storms tank, because both exits sit on a raised lip, its a right pain in the butt....
good luck fella....
good luck fella....
- agentpineapple
It's the petrol that can make them rusty in the first place over time. How about vinegar as a cheap option or coka cola it works down toilets and sinks for limescale. A couple of litres of cola is cheap as well.
- bluestoesonnose
Bought some stuff from Halfords (no really!) a few years ago and it's great, just don't mix it as it says, I trebled the mix and it worked great. Can't remember what it's called now but worth a look
thank you gents.,
will have a think and a look round.
marty dont worry its not a tank off a storm. its a little project i am playing with.
no prizes for guessing what its off cos ive said twice already (but no one reads my posts anyway)
a tank that size get it soda blasted
is it for a boat ?
is it for a boat ?
no not a boat.lloydiecbr wrote:a tank that size get it soda blasted
is it for a boat ?
motorised 2 wheel transport
- bigtwinthing
christ how much tea does that flask hold???lumpyv wrote:thank you gents.,
How bad is the rust inside the tank
quote "christ how much tea does that flask hold???"
ha-ha i reckon theres about 50 or 55 miles worth in there? dont know for sure yet though cos i havent had it going .
- Miztaziggy
Put some powdered aluminium inside and a lit magnesium ribbon
well that's difficult to say? I don't think its going to be too bad if I give it a good shaking with some petrol and some nuts or whatever.macdee wrote:How bad is the rust inside the tank
its certainly not rusting through in any way.
just petreal it and have done with it...
