Love my new Firestorm.What next?
SparkyVTR
Post by SparkyVTR »
Hi everyone, newby Mark here.
Only done 120 miles on it so far but already hooked!
2003 model, 8000miles, standard. What do you guy's think I should do first?
Thinking of changing cans. would like to stay legal. any idea's?
If I change cans do I need to do anything? Re-jet?
Thanks. Mark
chric
Re: Love my new Firestorm.What next?
Post by chric »
first thing change cam chain tensioners to manuals
what colour is it :?:
you got any pictures
popkat
Post by popkat »
Hi, If it really is an F2 or F3 (not an old stock FX/Y) then if you change the cans you'll need to blockoff the "pair" valve system or it'll sound like one of those Farty sounding fireworks all the time.. got cans on mine with std air filter and blocked off pair, runs fine.
SparkyVTR
Post by SparkyVTR »
Its a very clean blue one. how much are cct's? when I did my CBR600 few years a go they were £25. Thanks
Log book says model F-3? how else would I find out if thats right? Thanks. Mark
F3 should have gold/bronze engine cases and black faced speedo & rev counter. F2 has black engine cases and a white faced rev counter (I think or it might be the speedo! :think: ).
F3 clocks
F3 engine case colour
Welcome to the Band of Blue Brothers, you have shown excuisite taste my friend. And I am completely unbiased. :lol:
popkat
Post by popkat »
F3, should have lcd display on righthand side of clocks. if you look at the front cam cover you'll see an extra cover on top with a hose coming out the side, thats the pair valve(reed) cover for the front cylinder, you'll also have a fuel range of around 150 miles as it'll have the larger 19litre tank, also under the seat on the subframe will be a white sticker with F3 on it. there's other differences too but these should tell you for sure, there were alot of late registered earlier models.
After the ccts have been done I'd look at fork springs and rear spring change . Then brakes then a bafflectomy :-)
welcome to the brotherhood buddy... :thumbup:
post some pictures when you get a chance. cct's are the most important, as for cans, good quality ones will probably not need rejetting, but if you decided to get a k&n filter the bike will need regetting and possibly dyno time. if you don't want the cans to be that loud, get road cans or race cans with db killers.
lets hope we see some more sunshine so you can have some fun with your new toy... :wink:
Change the colour :lol:
As has been said cam chain tensioners are the first thing to do so it's is mechanically safe. Have a read the workshop knowlagebase and there's loads of ideas and info in there.
Welcome :beer:
darkember
Post by darkember »
Welcome M8. Blue is the best colour :thumbup: :thumbup: BTW there is a whole section on removing the PAIR unit, I have done it to mine which is an F2 model. Below are the links to the method & parts you will need.
https://tpoparts.com/cat093/index.php?r ... ath=91_101
Here is the thread on the removal of the complete unit.
http://www.vtr1000.org/phpBB3/viewtopic ... al#p261232
popkat
Post by popkat »
The link shows well how to do it. on mine i didn't do block off plates, i just got some rubber hose with the correct inside diameter, cut it short and put a cut down bolt in the end then a zip tie around them, did the same for the airbox too. cost nothing as i had some hose lying around.
Warning note though, blank off the air box from the outside as shown in the link, DON'T blank from inside the airbox, the pressure will suck the blank straight into the carbs. sounds obvious when you think about it but some people won't.
Welcome to the team, bike sounds like a bargin..shame about the colour :lol:
SparkyVTR
Post by SparkyVTR »
Thanks everyone. Really helpful. Best place to get cct's? Will try and upload some pic's. M
Whoa Nelly
Post by Whoa Nelly »
Top choice Sparky :thumbup:
Welcome to the wider Storm family as well as the slightly more discerning Blue Brotherhood. Oh hang on, which blue is it?? :lol:
WN! '99 Firestorm, furry dice & 2lbs of dead insects
Greetings
Krieger, APE and Bazza CCT's > http://www.vtr1000.org/phpBB3/viewtopic ... 16&t=22720
SparkyVTR wrote:Thanks everyone. Really helpful. Best place to get cct's? Will try and upload some pic's. M
