Hey All
Coming up to service time.
How do I tension the APE Manual CCT's correctly ?
Matt
APE Manual CCT's
APE Manual CCT's
1998 VTR, One of the red fast ones, Harris Laverda
Re: APE Manual CCT's
How many mikes have they been on the bike for. I doubt they need adjusting unless they have not been set up right to begin with. Once manual tensioners are fitted they should not require any adjustment for about 20,000 miles. The best time to do them is when valve clearances are due to be checked/adjusted as they will need re-setting anyway if clearances are to be adjusted.
As for setting the tension.
http://www.vtr1000.org/phpBB3/viewtopic ... nt#p258584
You may want to read this thread on setting the timing
http://www.vtr1000.org/phpBB3/viewtopic ... 326#p60936
