Trying to trace a stutter when running at a constant throttle.
30mph or 40mph or what ever I'm getting a hesitation and the engine kind of hunts.
So I've taken the tank off tonight, checked all the rubber tubes and they all look good.
Check for kinks (none) just like me
The large pipe on the offside from fuel tank to carb I can blow down but the nearside one seams blocked.
Is that right? Can't think it can be.. Or should I at least hear a hiss?
Second question is in regards to a sticky throttle, it's just slow to return and I can't see why.
Cables look ok, spraying cleaner on the near side spring and am just trying WD40 on the off side spring.
Any one fixed this by spraying?
Styler4077
