Help please any boffins
seb421
Post by seb421 »
Right now i've got two aquariums and three snake vivariums the heat in my room when its a warm day is unreal!!
Window Open, Door Open, Fan on room was an indicated 27c which is just bonkers uncomfortable and also meant the snakes may have trouble thermoregulating as they should be able to get down to 25 or 26 if they want in there viv's cool end
I'm looking to fit an extractor fan to my door and somehow wire it up to a switch that will turn on at say 21c to help pull some heat out the room as i can't leave the window open during the day if i'm out as their is the risk of theft (downstairs room) and the neighbours cats getting in again
Can anyone link to me to a temperature controlled switch thing that i can wire into the extractor plug thing
All i want is a unit that will activate over a given temp over 21c turn on, under 21c turn off etc
Massive kudos points to anyone that can point me in the direction of the correct product for me
adyf
Re: Help please any boffins
Post by adyf »
Hi seb,if you can afford it best thing would be a conservatory air con unit that goes through the wall,easy to fit and fairly quiet,consevatories get very hot so should cope easily with internal room,wicked sell one and b+q ,ok buddy take care ady f.
seb421
Post by seb421 »
bloody hell mate that would be ideal but a little too extravagant and expensive for me
bazza696
Post by bazza696 »
You should be able to buy a room stat and wire the +ive wire through that, its only a switch so would do whats needed. Depending on the current draw on the fan you may need to run the stat through a relay so you don't blow the stat.
Xenocide
Post by Xenocide »
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
darkember
Post by darkember »
Failing to get the stat sorted you could spend your days sitting by the tanks with a water bottle with a misting jet. This has one added benefit, its burglar proof :lol: :lol:
seb421
Post by seb421 »
thanks chaps found this
http://www.ebay.co.uk/itm/SMSCOM-SMART- ... 3ccb7c7a6c
by same people think its ideal if a little pricey tho....
seb421
Post by seb421 »
