Damned headlight screws
- Redthunder
Anyone else had problems trying to undo the lower 2 of the 4 screws securing headlamp to fairing?
Re: Damned headlight screws
Yep all 4 of mine were stuck .
I had to prize them out
- Redthunder
Which method did you try? Think they have crap brass knurl nuts sunk in fairing which get stuck to screws?
Yep them things :-( . You can drill them out but I just pulled them out then filled the holes with plastex and then drilled and tapped them again .
- Redthunder
Thanks Lloydie
- cliveyandrews
- Contact:
I plugged mine with clear tubing and screwed into that....
Sent from my iPhone using Tapatalk and my fat fingers and thumbs....
Audi, Vide, Tace
Audi, Vide, Tace
Yup - Had to lay it face down a towel and carefully drill them out - replaced with ss allen headed bolts with some copper grease.
If you damage the nuts then get some suitably sized replacements and get some plastex as Lloydie recommends: http://www.ebay.co.uk/itm/M6-Knurled-Br ... 1e7b868277
