hey guys i took the hawk to the locall drag strip last night. I've got a K&n 2brothers slip ons and a un tuned jet kit. The best i could manage that night was a 11.9 with a reaction time of .548 with .500 being a perfect light. I did beat this guys 600rr 3 different times and he beat me 1. he would get a lower e/t but i would get through the finish line first . this was because i was getting a sh1t load better launch than him and the torque was crushing him. the 6rr has 1 down 2up sprockets and i also have the same mod waiting to go . This should help me out alot also i need to get a full system . I 'm thinking about getting 11:1 compression pistons for christmas so this should be nice.
later just felt like sharing. the humidity was 98% so i think this why i did so poor
I have basically the same package as you do: two bros slip-ons, dyno jet jet kit, K&N airfilter (not supposed to help much if any) and stock gearing.
Here in Phoenix on a 105 F evening I usually do 11.4's, with my best ever of 11.32 a couple of months ago. Not bad for a bike with 50,000+ miles on it!
Short shifting the bike seems to help, going above 9000 rpm is a waste of time and hurts my times.
Tires don't seem to matter, I have had anything from race take-offs, Sportech m1's and even MEZ4's... back tire never spins. A burn out is a waste of tire too, I only do one when I am showing off.
I don't come off the line too hard either. I let the clutch out fairly quickly with the rev's low, then let the throttle do the rest. You might get a slightly better time slipping the clutch, but a toasted clutch isn't worth a .10 in time for me.
Keeping the engine temp up also seems to help, particularly with consistancy. I have noticed that by the end of the evening, with the bike cooled off, my times would be all over the place. Now I idle the bike between runs for a couple of minutes just to keep the temp up.
The announcer at the drag strip will love your bike! I have a wheel up launch almost everytime. Not much, just about 6 inches or so... but people really like to see you carry the tire.
You know the Austin Powers movies? I have always wanted to date someone like Allota Fagina... but I always seem to date her sister Sandy.
hey ,thanks for the info . What kind of jets like what # are you using and where do you have your needle at? those are some bad ass times. I'm probably going to be getting j&e hign compression pistons and stage 1 yosh cams for my bike. So this should help. i never really thought about short shifting it i would just take it to where it touches the red then shift.
hmmm.... I will have to check. I don't really remember. I had a local guy with a dyno do the set up, and I don't have the most confidence in the set up. I get some pinging and the bike seems to run hot now, but according to the exhaust gas analysis it should be fine.
I *think* it was 190 front 185 rear, 4th out on the needles, and 2 1/2 turns out. Not 100% on that though.
dude its still like freaking 93 degrees in florida. you should come on over.
actually the last couple evenings have been in the upper 70's buuurrrr its cold just kidding. I still ride my storm in 40 degree weather. It sucks because the storm is my only meens of transportation so i have no choice. but i'm sure its way colder over there
