Headlight/nosecone screw and housing issue
VenerableArc
Post by VenerableArc »
Came to remove the headlight from the nosecone and I failed getting the last screw out - its one at the bottom with the bracket on it. It started to round so I got some uni-lease (a releasing agent that I use at work for helping to undoing bolts etc). This worked to a fashion. The screw finally started to turn however; its turning the threaded housing inside the plastic!!
I have tried to grip the threaded housing with a small set of long nose pliers but this isn't ideal as the surface area showing is very small and the screws were thread locked in. I am not sure where to turn next, I could try and remove the threaded housing but the would mean the headlight would only be held on by three screws in the future.
I appreciate it is hard to try and visualise without photos so will get them up after work but any suggestions on how to get the screw out would be fab :thumbup: I really dont want to be buying a new nosecone.
Matt
Some people deserve a high 5. In the face. With a rock.
Re: Headlight/nosecone screw and housing issue
If you can't drill it out due to the proximity of the headlight, then you might have to carefully hack it out from from the plastic. Then rebuild using plastex http://www.plastex.net and if needed another brass threaded insert. http://www.tappex.co.uk
What about dremelling the head of the screw off.
Same thing happened to me and I replaced the crappy screws with s/s allen bolts & some copper grease
VenerableArc
Wicky wrote:If you can't drill it out due to the proximity of the headlight, then you might have to carefully hack it out from from the plastic. Then rebuild using plastex http://www.plastex.net and if needed another threaded inset. http://www.tappex.co.uk
Dremmeling the top off would be a good bet :thumbup: it would allow better access to the threaded housing. If that fails then I will have to go down the plastex and tappex route.
I am going to have to change all of my bolts and screws this winter, 90% of them are corroded and rounded! Loving the tappex website! Thats very useful for work too!!!
Cheers Wicky :beer:
Sound like you just need to pull it out .
I had the same issue with mine last winter so I just pulled all four out and then filled them with plastex then when set I drilled and tapped them .
Redthunder
Post by Redthunder »
I just dealt with this problem. I turned the screw clockwise thus forcing the brass nut out with it, then used following to replace. Worked a treathttp://pages.ebay.com/link/?nav=item.vi ... 0708445144
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
Destined4bikes17@gmail.com
VenerableArc
Thanks for the response guys :) I will try when I finish work.
Matt
cliveyandrews
Post by cliveyandrews »
Redthunder wrote:I just dealt with this problem. I turned the screw clockwise thus forcing the brass nut out with it, then used following to replace. Worked a treathttp://pages.ebay.com/link/?nav=item.vi ... 0708445144
Now they're useful. I'll be buying a set as I have one screw held in with plastic tubing!
What size thread is it?
Audi, Vide, Tace
VenerableArc
Managed to get the housing out by cutting a small slot out of the plastic. Just got to get some Plastex when I am ready to assemble after my headlight mod. I will be using a self tapper for this one as it will be held on by three original screws.
It looks like M5 buddy.
