Air Fuel screw adjuster
Moderator: VTRDark
ebenviljoen
Post by ebenviljoen »
Any one have an air/fuel adjuster for sale? I'm tired of taking everything off to tune the little things. Done my valve clearances and replaced my inlet cams with exhaust cams. If not Ill get one of skewbay, thaought ill check here first
thanks
Jonesey
Re: Air Fuel screw adjuster
Post by Jonesey »
Which is the exact part you're after? just the screw itself?
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
ebenviljoen
Jonesey wrote:Which is the exact part you're after? just the screw itself?
No the angled screw driver mate, to adjust the screws
I use one of the following and it's still a struggle, especially the rear carb.
http://www.ebay.co.uk/itm/Motion-Pro-08 ... 51b0d6b296
Your other option is one of these but I have not tried them.
http://www.ebay.co.uk/itm/180752947140? ... 1423.l2649
I would have thought these would be even more tricky as they are not as shallow.
