mattycoops43 wrote:8541Hawk wrote:Or as we call redneck engineering here in the states......
put the bike in gear,
place a 2X4 through the spokes in the rear wheel and rest it on the swingarm.
Now when you turn the bolt, the wheel will rotate until the 2X4 locks the rear wheel and swingarm together and you are good to go
This!
I have used this to get front sprocket nuts off, and I am sure clutch basket bolt will be less torque than that!
Nope. Look at the torque figures in the manual.
70, I think, for the clutch centre nut...
I posted something ages back in the Workshop Knowledgebase, using an old can strap round the generator rotor to clamp it against the LH side footrest.
I was just using whatever came to hand, but it worked well enough.
