Exhaust clamp sizes
darkember
Exhaust clamp sizes
Post by darkember »
Can anybody tell me the 2 sizes needed for these clamps. The 2 smaller ones to attach the link pipes to the header assembly & the 2 larger ones to attach the cans to the link pipes.
Cheers Dark
Re: Exhaust clamp sizes
can end is 52mm IIRC but I could be wrong.
I didn't know that the other one was smaller.
darkember
Post by darkember »
Ones for the end cans must be 51 - 57 & the link pipe ones not sure if they are 43 - 47 or 47 - 51.
Here is where I intend to pick them up from:
http://www.ebay.co.uk/itm/MIKALOR-W2-St ... 4897.l4276
Can depend what kind of link pipes you have. I've had to use different sizes if using standard cans or Microns, as they can attach slightly differently. Best to throw what you're using together and grab a tape measure. Highly recommend Mikalor W4 fully stainless :thumbup:
darkember
Post by darkember »
Wicky wrote:Can depend what kind of link pipes you have. I've had to use different sizes if using standard cans or Microns, as they can attach slightly differently. Best to throw what you're using together and grab a tape measure. Highly recommend Mikalor W4 fully stainless :thumbup:
After measuring ordered a set of 47-51 & 51-55. Mikalor W4 ok, if you are an all weather rider, Mikalor W2 will suffice for this job. :thumbup:
