Fork Oil - what weight?
My forks are going off to Brooks in Bradford (couldn't afford for them to be properly Roger'd), what weight fork oil do you recommend for standard springs (please don't suggest other, expensive ones!!) and a 12 stone rider? Seen mentions of 7.5wt on here, believe standard is 5.0wt?
Re: Fork Oil - what weight?
Mix 10 and 5 weight to get 7.5 weight if you can't find that weight. There should be one or three threads on the subject. And new springs would be a worth while addition while everything was apart and getting serviced. Bit like putting on the same pair of underpants after having a bath…. ;)
- carmanbikes
I had mine done with Rodger and he used 7.5
- turbo_billy
IMHO Dave Brook knows his stuff so I would entrust the choice of oil to him when he rebuilds them. I know when he did my SP1 forks he used 5wt as he said anything firmer seemed to upset the balance on the SP. Did a first class job for me and the bike handles like a dream.
Bit like putting on the same pair of underpants after having a bath…. ;)[/quote]
Nothing wrong with that just give them a good sniff before putting them on.
