Coerce Sprocket Cover/Braided Hose
South Coast
New South Wales
Australia
New South Wales
Australia
Re: Coerce Sprocket Cover/Braided Hose
Interesting route you have run for the clutch line. I would have run it the other side of the frame over the cover. Lovin the shiny geny cover.
Interesting angle of the link rod to gearbox lever as well.....
Do you get chain lube on your boot?
The thing that puts me off is that quite often the seal on the clutch pushrod leaks, and the full cover allows this to drop off the underside and onto the ground.
Not sure where it would go with one of those fitted.
I fitted a rubber sleeve over the braided line where it goes behind the frame.
I have had this fitted for about 3,000 miles and have not had any problems with oil etc.
I am very anal about my bike and keep it clean.
No salt on the roads here and ride all year round.
South Coast
New South Wales
Australia
New South Wales
Australia
