pannier rack for throw overs
Started on the next little project !!
A pannier rack using the rentec rack .
I bent up two strengthening rails to go from the pillion bracket mounts to the rear of the rack ,
I'll use these to mount the base of the pannier frames to .
I need to order some more tube to make the other bits but when done it will all bolt on in minutes
Did a little more from scrap pipe just so I know where to bend it
Re: pannier rack for throw overs
reserved 2
reserved 3
reserved 4
reserved 5 . hope you dont mind me doing this but i hope to have it done in a few updates .
nice bit of pipe bending there Lloydie, you have matched the shape of the under tray well.
I assume you will be putting some extra frame work out horizontally to take the forces that normally end up going into the fat part of the tail fairing......and breaking the plastic mounts
AMCQ46 wrote:nice bit of pipe bending there Lloydie, you have matched the shape of the under tray well.
Yep that's why I decided to build it as I didn't want to damage the plastics or the paint .
Can't order the pipe till next week but I have enough to be getting on with
bazza696
Post by bazza696 »
Need to polish those vipers before coming to the maintenance day.
bazza696 wrote:Need to polish those vipers before coming to the maintenance day.
They will be don't worry :-) I'm going to get one of them polishing kits of eBay as I've already wet&dry sanded them .
chric
Post by chric »
Welcome to the rack club:D
neons next?
chric wrote:Welcome to the rack club:D
neons next?
I was thinking air ride suspension :-)
Little update
Ckennedy
Post by Ckennedy »
Tis looking good lloyd :thumbup:
