Centre Coller
carmanbikes
Centre Coller
Post by carmanbikes »
On the rear swinging arm, right hand side sat on the bike, the link that has 2 bearings there is a centre coller part number 52141-MBB-000 it has one side slightly bigger than the other does anyone know which way it goes in, Thanks :?
Re: Centre Coller
carmanbikes wrote:On the rear swinging arm, right hand side sat on the bike, the link that has 2 bearings there is a centre coller part number 52141-MBB-000 it has one side slightly bigger than the other does anyone know which way it goes in, Thanks :?
Hope this helps, the collar flange rolls out towards the outside of the swingarm.
carmanbikes
Re: Centre Coller
Great that Jamie, Cheers, Would you Know also part number 52142-MBB-000 number 8 on the fiche one goes on the outside of the right side, does the other go on the inside left or inside right, Thanks Again Lee
Re: Centre Coller
Good question! I can't remember and the microfiche doesn't make it particularly clear. I'll be taking my swingarm off again this week so I can let you know, if no one else chips in first :thumbup:
carmanbikes
Re: Centre Coller
Jamoi wrote:Good question! I can't remember and the microfiche doesn't make it particularly clear. I'll be taking my swingarm off again this week so I can let you know, if no one else chips in first :thumbup:
Thanks Jamie
