Would this clean injectors?
what fluid would you fill it with to clean the injectors also?
should be able to fit car and bike ones in as it says will fit a dvd
http://www.ebay.co.uk/itm/CE-ONE-Year-W ... 43c35bead2
Injector clean
Injector clean
- Tam Cunningham
- Location: Perth, Scotland. thomaspcunningham@btinternet.com
Re: Injector clean
Check the forum post/links to the Aldi site and offers as my local was selling one of these just the other week
Re: Injector clean
Are they good enough to work on the injectors?Tam Cunningham wrote:Check the forum post/links to the Aldi site and offers as my local was selling one of these just the other week
- Tam Cunningham
Re: Injector clean
I dare say they would clean the injector itself however getting an ultrasonic unit and just throwing the injectors in will not clean them internally.
It may take a few hours to clean the injectors to spec with proper equipment but you need to flow check after using calibration fluid.
I don't want to put you off from trying to do this but the results may be disappointing
Re: Injector clean
yeah i read somthing about reverse flowing them in the past ? i was just thinking i could blow some stuff through them give them a wiggle
