As I can't post in sales and wants yet I'm posting here.
Does anyone know where I can buy a Fuel Tank Prop from? Propping it up with a piece of dowel etc won't cut it for long.
All help appreciated.
Fuel Tank Prop
- Contact:
Fuel Tank Prop
It may only be my opinion but it's mine!
~ My Bikes 2014 VFR1200F & 2000 VTR1000F ~
Re: Fuel Tank Prop
Honda Special Tool > £5 per meter
Re: Fuel Tank Prop
Yep I used a length of 5mm bar to prop it up
Re: Fuel Tank Prop
If you referring to the U shaped thing that comes with the Honda toolkit I don't see the point in them. All they allow you to do is remove the rear plug. I prop the front of the tank up with a long 3/8 drive extension bar, the same one I use on my rachet to undo the front mounting nuts. It clears the top of my screen so can easily spin the rachet around fast without crashing into the screen.
Re: Fuel Tank Prop
Hold the front tank mounting bracket in your teeth, resting your forehead on the screen edge for location and to save hurting your neck after ten minutes or so.
Then with the preferred hand, right if you're right handed, not if you're peculiar, undo the vacuum line, and reaching under the tank with your other hand, loosen and release the drain tubes front off the tank base.
Now, with the other other hand, (following me?) pull the two fuel line off, remembering that you may have fuel pissing everywhere if you have a 19 litre tank, but then, you deserve it.
now, with the other other other hand, disconnect the OLOD sensor and then, not using the full strength of Denture-Fix alone, lift off the tank, with your other, other, other, other hand under the front tank mount, and the other, other, other, other, other,other hand (or an assistant) lifting the tank, never letting the left hand know what the right hand , or hands, is/are doing.
Once you have the tank in mid air, use the other, other, other,, other, other, other hand to clear a space on the workbench to put it down.
Using your other, other, other, other, other, other hand, place a call on your mobile to the significant other/next door neighbour/significant next door neighbour to come to your aid so that you can put the tank down.
With the other, other, other, other, other other, other and other other, other, other other other and other hands, pour yourself a well-earned beer.
The order a tank prop from Ebay; you know it makes sense.
And you're worth it
And you're worth it
Re: Fuel Tank Prop
Wouldn't it be far simpler to get an Octopus.
Re: Fuel Tank Prop
The point of them is quite simple actually... Stick it in there, put a towel or something at the rear base of the tank and use a bungy to the rear of the bike, and you can do without something getting in your way at the front... But to each their own...cybercarl wrote:If you referring to the U shaped thing that comes with the Honda toolkit I don't see the point in them. All they allow you to do is remove the rear plug. I prop the front of the tank up with a long 3/8 drive extension bar, the same one I use on my rachet to undo the front mounting nuts. It clears the top of my screen so can easily spin the rachet around fast without crashing into the screen.
