exhaust gasket question
chric
Post by chric »
do i put it in the exhaust first or the pipe im connecting it to?
at 6 quid a go dont want to mess it up
Re: exhaust gasket question
In the exhaust first , use lube and if it don't slide in easy open the hole up a little by tapping it with a ball pin hammer till it slides in .
lloydie wrote:In the exhaust first , use lube and if it don't slide in easy open the hole up a little by tapping it with a ball pin hammer till it slides in .
Sounds like Peter Sutcliffes foreplay!!!!!! :oops:
Be very careful tapping it with a hammer as the end starts to fray and bend which can make things difficult sliding a pipe over :roll: A bit of lube would be better to help things slide into place. :lol:
cybercarl wrote:Be very careful tapping it with a hammer as the end starts to fray and bend which can make things difficult sliding a pipe over :roll: A bit of lube would be better to help things slide into place. :lol:
Tapping the pipe not the gasket !!!! Lube is for the gasket
good to see Lloydie uses lube on inanimate objects that feel no pain, but for Virt he goes in dry :lol:
Got to make him squeal !!!
Mav617
Post by Mav617 »
And this goes for link pipes for end cans as well as the standard pipes?
chric
Post by chric »
lube as in?
Something slippy......Grease, Vaseline, KY :lol:
A bit of grease should do the trick. Juts don't be suprised to see a bit of smoking as it gets burnt off.
chric
Post by chric »
dint need any just slid straight on on the left side see what its like tomorrow
