After a bit of info.
darkember
Post by darkember »
What is the point of the coolant lines that connect to the carb bases as they look as if they just loop through the connecting pipe & out again. Are they there not for cooling but preventing the carbs from freezing??
Re: After a bit of info.
I removed mine within a week of getting the storm and it's fine however I don't ride below 10'c .
For what I've read they are heated to help fuel atomisation and to prevent carb icing in sub zero temps .
darkember
Post by darkember »
Thought so thanks Lloydie :thumbup:
lloydie wrote:For what I've read they are heated to help fuel atomisation and to prevent carb icing in sub zero temps .
That's what I would have said,
They also help to atomise the fuel.
If atomising the fuel was a benefit you could lag them carb heater pipes with asbestos tape for extra performance.
Ripped mine off, saved the weight of the pipes PLUS the weight of the coolant in them- Result!
You would make a great ad for Weight Watchers Tony. :lol:
darkember
Post by darkember »
Ok so if you remove them does one link the pipes or cap off each end??
darkember wrote:Ok so if you remove them does one link the pipes or cap off each end??
link the long one on the left to the water pump . put the other in the bin.
