ANYONE NEAR DURHAM TO HELP WITH MY CCTS
ninja636109
Post by ninja636109 »
I could do with a hand with my ccts from someone who has experience any one near durha.
Re: ANYONE NEAR DURHAM TO HELP WITH MY CCTS
I would recommend scottyhatchi in South Shields - but I won't….
simo
Post by simo »
Working 12/7 at the moment. How far have you got with the job?
Theres A Hare in The Turnips.
ninja636109
Stripped the bike down I'm just really anal about making sure it's done right I don't want to wear the chain or have rattles was thinking if someone has done a few they would have a better idea... Or is the walk through pretty much ideal. I don't like taking the bike to a garage as I think they throw them back together..
Mate if I didn't have my bike still in hundreds of bits to get back together to go the tt I'd gladly have come across to help. I'm very anal also ( down Lloydie ) but you really cant go wrong if you follow the guide! :thumbup: any questions just ask on here.
ninja636109
Cheers bud I'm going t set about it this week lol.... Are the rocker cover gaskets reusable?? Never had them off..
Showing your age there calling them rocker covers :lol: Yes cam cover gaskets :wink: are rubber so therefore re-usable unless broken or severely perished. If your lucky they will either stick to the groove around the inside of the cam cover or stick on the head when you lift the covers off, if not you may want to apply a little gasket sealant around them to hold them in place when putting the covers back on.
If they are not seated in the groove properly you may end up with an oil leak, so pay particular care to re-seating the gaskets and covers, especially the front cylinder at the front and rear as it hangs down and the gasket can slide out when tightening the covers. Also pay particular attention around the U shape where the plug goes and the D shape bits at either end. When putting the covers back on DO NOT over-tighten the 10mm bolts otherwise you risk snapping them in the stem.
How's things going with this job ninja?
ninja636109
Tonight is the night lol.... I'm sure it will be fine gonna check valve clearances aswell at same time... And get bike back on the road for the weekend hopefully lol
ninja636109 wrote:Tonight is the night lol.... I'm sure it will be fine gonna check valve clearances aswell at same time... And get bike back on the road for the weekend hopefully lol
Yeah good time to check em mate. Enjoy :thumbup:
ninja636109
Well valve clearences spot on... Even after 20k.... Good stuff also ccts all done and set to 7mm of slack... Happy I'm now running again
