PAIR engine
gaz62
PAIR engine
Post by gaz62 »
I have just noticed the replacement engine l have got for my bike has the PAIR system on it , the bike doesnt have it , will it be ok to just blank off the hoses or will l need to modify the bike ? Thanks Gaz
Re: PAIR engine
Swap the cam covers for your old ones and job done
gaz62
Re: PAIR engine
Post by gaz62 »
Thanks Lloydie
Re: PAIR engine
Just check condition of the O ring ! You will see it when you swap them over
Re: PAIR engine
Don't forget to cap off the extra pipe on the carbs.
PAIR System removal
gaz62
Re: PAIR engine
Post by gaz62 »
l am using the original carbs so that shouldnt be a problem should it ?
Re: PAIR engine
No not a problem :-) just that O ring to check
gaz62
Re: PAIR engine
Post by gaz62 »
Thanks for all your help , l am sure l will need some more before long !!
darkember
Re: PAIR engine
Post by darkember »
& use the o rings even if you use the older cam covers as the PAIR cylinder heads all have the hole for the oil to flow through all pre PAIR cylinder heads don't :thumbup:
