Timing Light with Coil On Plug Stick Coil
Simple question:
How does one connect an inductive pick up on a Timing light with Coil on Plug Stick Coils? Usually the pick up would clamp around the HT lead but with stick coils there isn't one :confused
Some of the better quality/more advance Multimeter's would include an inductive pick up too for RPM so the same issue there. :confused
Virt
Re: Timing Light with Coil On Plug Stick Coil
Post by Virt »
Something Carl doesn't know?! :O
nt1980
Post by nt1980 »
I no some garages have an extender so you would put this on the plug and the meter / timing light then the coil goes on after but i guess there wouldnt be that much room on the front cylinder to do that only a thought.
At the Dymond they just put the pickup onto one of the low tension wires
Been through that already along with the R6 forum amongst many others Tony. It seams a lot of people are making an extender as has been mentioned, but thought there may be a particular adapter designed for the job. After searching loads I cant find anything and there seems to be no modern day timing light specifically designed for COP as most modern day engines have non adjustable timing.
Thought I would post as someone may have some other solution specifically designed for the job. Looks like timing lights may become a thing of the past. I seem to remember that Gunson made a light which had a tapered coiled wire on the end that went between the plug and lead instead of an inductive clamp. Mmm I shall have to make a lead up then as I can't find any other answers.
I wasn't sure if it would work on the low tension side Al, interesting, maybe on our bikes it does as there is higher voltage than norm and the pulse is there. :think:
Cheers guys :thumbup:
Virt I'm fairly knowledgeable but I don't know it all and I'm far from genius. :wink:
nt1980
Post by nt1980 »
something like this may be http://www.picoauto.com/cop-extension-lead.html probably make somthing out of your old leads :plainsmile
Good find :thumbup: bit pricey for what it is though. Like you say could make one out the old lead.
