my p reg firestorm symptom 1: riding along backfire loss of power electrics,the fuse in the starter solenoid had blown,
previous owner had fitted a 15 amp fuse?supposed to be 30 amp? any way electrics back on battery flat as !
friendly bikers give me a bump start,bike fires up, ride for about another mile,bike dies again fuse(30 amp didn't blow)but battery flat as a fart would not bump start,
(the previous owners seem to have done some shoddy wiring connections that would make my past bodge ups look professional??)nice man from AA recovers me home.
at home fitted a new battery as old one reading on multimeter 1.5 volts
went for spin same symptoms same nice AA man!!!!!!!!
at home i followed the starter circuit the 30 amp fuse didnt pop but was melting ??
i later found the positive lead to the starter motor had been stretched an improperly crimped(wrong size crimp-too big) the wiring was half-out loosely in the crimp,new battery plenty of juice lights and horn etc working just buzzing rattling at starter solenoid?
went on line and ordered a replica starter solenoid £15, for good measure and am about to get my crimping kit out and have a good once over around the loom with multimeter to check circuits?
i know the loose connection is one very probable cause,i couldnt find a negative lead on starter motor(short circuit) behind all the road gunk? how are they designed neutral to earth internally? any phots? well im off on my merry fault finding way in hope of some inspiration ? before i turn to alcohol
