cutting out
minibreaker
cutting out
Post by minibreaker »
when at the lights my ticks over about 1100 revs and every now and agin it cuts out with a thud it re starts fine but alos every now and agin it mis fires when i give it a little blip what could be causing this?? thinking valve gaps or dirty carbs what would you guys go for
Virt
Re: cutting out
Post by Virt »
Have you adjusted the TPS?
minibreaker
Re: cutting out
no how would i go about that. i have only had the bike a month so could that be the cause
Virt
Re: cutting out
Post by Virt »
Re: cutting out
Carbfart - raise the idle a notch to 1200
minibreaker
Re: cutting out
gonna do tps and sync carbs see if that helps
