Front exhaust manifold bolts sheered
Seven Of Nine Firestorm
Post by Seven Of Nine Firestorm »
I'm assumbing they are sheared off cus both look the same and the front exhaust manifold bracket is banging away the bike sounds like a tank, whats the best way to fix drill them out tap for M8 / M10 and rebolt ??? or was is it a press fit with gasket only ? Already tried the grips around to scew but to no avail loll.
Re: Front exhaust manifold bolts sheered
Have a read of this if you've not already:-
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=31728
Thanks for the heads up (y)
darkember
Post by darkember »
Be prepared to remove the head to drill and have a replacement gasket at the ready.
PARSLEYRIPPER
Post by PARSLEYRIPPER »
Or buy another engine week that's what i ended up doing, but mine had dropped all the valves from failed cct :evil:
