Original Honda undertray - tatty
fritzdog
Post by fritzdog »
Good Morning!! I wonder if anyone can help? My project Storm is slowly making progress, am working on the seat area at the mo, and I want to keep the original black moulded plastic undertray. But it's really old n tatty, bits of rubber stuck to it (these mostly come off with petrol) scratches etc. Is there a way of restoring this plastic to an acceptable standard (I know it's only visible from the underneath, lol), maybe shotblasting and heatgun, or is it a dead loss?
Thanks in advance,
Mick
vtrjames
Re: Original Honda undertray - tatty
Post by vtrjames »
the autoglym black bumper stuff the green gel stuff is good for that kinda thing, takes the black back to a nice new look especially if it has faded a bit.ive used it alot on that kind of thing.just give it a good hot wash first and dry it, if you can get it swarfega truckwash soap is a good cleaner / degreaser but i think its only sold in 5 gal drums.
As for the wear and tear/scratches, I would sand any deep scratches out and then maybe use some kind of polish like T Cut or something to try and smooth things back out. Boot polish works well to bring the colour back too.
Shauned71
Post by Shauned71 »
Heat gun works on oxidised areas but its also easy to mark the plastic. Myself, I would go with what Carl said because iv'e been doing it that way for a long time and it works.. Flat down any deep marks/scratches with fine paper, and for rough areas or stubborn dirt you could use a fine scotch pad then just buff it all back up... I know Carl only used it as an example but in my experience better than T-cut... farecla g3 abrasive polish, easier, works harder and longer because you can add a drop of water to stop it going dry. Have used farecla many many times to clean up plastic, car door mouldings, plastic headlamps that have yellowed and I could go on and on with examples.. I rubbed a load of deep scratches out of my storm mirrors... polished them up with farecla, you would never of known. As for any normal polish/gels... all good to make pretty but they won't give a long term solution, the flatting/farecla process will cut into the plastic effectively removing the oxidised plastic rather than just sitting on the top masking the problem. Will take a bit of elbow grease and patience but will work.
fritzdog
Post by fritzdog »
Thanks lads, I was just going to throw it away, but didn't want to really, lol. Will give it a go!!
