flat bars
flat bars
After the Wales trip I'm thinking maybe I should look into fitting some flat bars, not only to ease my aging wrists but because there appears to be some performance benefits too, namely greater leverage, better vision due to the more upright riding position, and judging by the pace of some of the flat bar equipped machines on Sat there’s certainly no detriment to performance.
But before I start sourcing the required bits and bobs I’ve a couple of questions, I know I’m going to have to cut the fairing and will need replacement brake lines but what about the wiring to the switch gear? Is there enough to reach or do they need extending?
Also what are the dimensions / model No of the bars, there seem to be lots of different shapes, widths, heights, rakes/rise etc which is most appropriate?
Regarding the mounting of the bars, the risers themselves I take it you simply drill the top yoke and bolt them on ?
Any advice or links to posts re fitting etc welcome
I've now gone all European and bought a KTM Superduke GT and Aprilia RSV1000R
Storm is now gone
Storm is now gone
Re: flat bars
Only wiring I had to extend was the horn wires by 2"
I put rental ultra low bars on mine , the are not the lowest as there ia a flat bar which has no rise. Then if you keep the risers below 1" then there is minimum cutting.
There is a thread with some pictures of when I did mine in the workshop section, but I can't search off the phone so hope somebody else links to it
Re: flat bars
these the ones ?
http://www.ebay.co.uk/itm/Renthal-Road- ... 540db30b63
Storm is now gone
Storm is now gone
Re: flat bars
Yesbudd wrote:these the ones ?
Re: flat bars
just missed some Protaper bars low bars and matching risers on the bay, they went for £15
Storm is now gone
Storm is now gone
Re: flat bars
cheers now I know what bars I need I just need to sourse some risersAMCQ46 wrote:Yesbudd wrote:these the ones ?
Storm is now gone
Storm is now gone
Re: flat bars
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=26908AMCQ46 wrote:Only wiring I had to extend was the horn wires by 2"
Re: flat bars
cheers for thr link
are these the type of risers I should looking at
http://www.ebay.co.uk/itm/7-8inch-Handl ... 2a36ccfb12
or these Royal Enfield beauties
http://www.ebay.co.uk/itm/BRAND-NEW-UNI ... 20eb2eb582
Storm is now gone
Storm is now gone
Re: flat bars
No those risers are not good for the Storm. You want angled risers so that the handlebars don't foul the fork stanchions which stick up above the top yoke. Something like these:-budd wrote:cheers for thr link![]()
http://www.mandp.co.uk/productinfo/5233 ... Two-Wheels
Or do what I'm toying with, and get a pair of these risers:-
Apparently with Ultra low Renthal bars and these risers you don't need to trim the fairing,
Re: flat bars
something like these thensirch345 wrote:No those risers are not good for the Storm. You want angled risers so that the handlebars don't foul the fork stanchions which stick up above the top yoke. Something like these:-budd wrote:cheers for thr link![]()
http://www.ebay.co.uk/itm/7-8-handlebar ... 20eca60c3f
Storm is now gone
Storm is now gone
Re: flat bars
Something like that is what I'm going to try when I get around to it. Those particular ones in your ebay link don't look right to me, at a guess someone has made them up, as the distance between the front and second bolt holes (the ones I have pointed out in red ink on mine in the pic below) are so much closer together than the genuine ones like mine. So I'm not sure if your listed ones will give enough clearance of the fork stanchions. If they go cheap enough you could take a chance I guess. Another point I have just realised is the ones you listed are only fixed on to the top yoke by the looks of it using one bolt per riser. The ones I'm using, both bolts (the ones pointed out with the red lines) go right through the top yoke, meaning you have two fixing points per riser. I suppose you could use longer bolts to the ones you listed to give four fixing points, but IMO the holes would be very close together and could possibly cause a weakness in the top yoke. Personally I think I would forget the ones you listed, although of course it's your choice.budd wrote: something like these then
Re: flat bars
your right the 2 fixing bolt holes do look close together, and as you say could weaken the top yoke, but I'll keep an eye on them and if they go cheap enough they may be worth a punt, at least I'll have something tangible to work with, TBH I’m in no rush to get it done I’ll likely SORN the bike at the end of Sept till new year so I’ll have plenty of time to work out what’s needed and source the bits,
Storm is now gone
Storm is now gone
Re: flat bars
Good call Chris, those stepped back risers look like they would work just perfect.... I fitted mine so the Ctr of the bar is exactly above the head stock bolt, that ensures you miss the fork legs and also have enough clearance to miss the tank when the bars are in full lock
Re: flat bars
I will keep an eye on this thread as I want to to bar conversion on my blue storm but not if I need to cut the fairing
Re: flat bars
Cheers AlAMCQ46 wrote:Good call Chris, those stepped back risers look like they would work just perfect.... I fitted mine so the Ctr of the bar is exactly above the head stock bolt, that ensures you miss the fork legs and also have enough clearance to miss the tank when the bars are in full lock
