Removing broken mixture screw
I thought it was time to sort out the carbs. suspected that the something was not right on the front pot. When it came to reset the mixture screw, it is stuck solid (front). Got a spare parts set, also stuck solid.
Any advise on getting them out please.
I am running on my default spare, spare set that is my base line But was going to modify my other set with a 6 Sigma jet kit i have.
Re: Removing broken mixture screw
There very brittle so take it easy ,
Gt85 helps .
I used a pin hammer and a sharp nail to tap it round
Gt85 helps .
Tried the pin hammer and punch technique to no avail.
I think i will try a soak in paraffin, and some heat next. Then it if that don't, drill and stud extractor.
One body is already looking like a write off and i was hoping to get a good set out the two.
Assuming i do get them out, are replacements available and where?
I prefer plusgas lube ,really penetrates if left over night ,sounds daft but if you can make a little plastecene funnel/dam and fill with plus gas will shift it.
Replacements are available from the superhawk forum and are better made look up thumb screw
I used an easy-out to remove a seized carb screw...
But I was VERY lucky!!
Jamie
i need lucky tooJamoi wrote:I used an easy-out to remove a seized carb screw...
lloydie wrote:Replacements are available from the superhawk forum and are better made look up thumb screw
Yes i saw them just wondered if anyone had a batch this side of the water?
A batch ! No but I have them fitted to mine
this is not going to be easy ..... is it .... i will be so p155ed off if i cant salvage it .... but there you go
Just buy some off JackFlash on Superhawk. Best tuning part for the bike ever. They are as good as they look.StuartWags wrote:lloydie wrote:Replacements are available from the superhawk forum and are better made look up thumb screw
I have a scrap set of carbs due to using easy outs, they split the brass and then the ally surround.
Yeah, not ideal. I wouldn't try it again.tony.mon wrote:I have a scrap set of carbs due to using easy outs, they split the brass and then the ally surround.
But it did work
Jamie
Just but some carbs, why faff around for £50
When ever I see cheap carbs on eBay (£20ish) I pick them up .
I have 3 good sets and 4 good for parts .
As I like to try different settings (lift holes and stuff) it's easier just to swap the carbs than mess with them .
And sometimes I get lucky and get a jet kit too :-)
