Rear Brake Drag
Rear Brake Drag
Hi Guys hope someone may be able to shread some light on this, Rode the bike today and noticed that the rear brake feels like it is dragging, when you push down on the foot brake it feels real firm and you don,t have to push far for it to lock, plus the rear disc was extremely hot, any tips
Re: Rear Brake Drag
Yup. Caliper off, strip it apart and do a rebuild. get a caliper rebuild kit from wemoto it's only a few quid and it's a really easy job.
Re: Rear Brake Drag
Sweet as, for that, will look into it, can't have all that power being held back
Re: Rear Brake Drag
Also check the slid pin and rubber boots ,
Re: Rear Brake Drag
Re: Rear Brake Drag
Call me stupid but you say the slid pin got a pic of said slide pin?
Re: Rear Brake Drag
OK...Hey Stupid here you go...monaro427 wrote:Call me stupid but you say the slid pin got a pic of said slide pin?
Although it might be no.12...I'd check both & lube accordingly.
You'll have to excuse Lloydie, he's not dyslexic he just can't spill proper being a numpty Midlander...
Re: Rear Brake Drag
Cheers for that will lube if needed and will do the disc thingee, clean up etc as in one of the other subjects
Re: Rear Brake Drag
Apologies :-(
Re: Rear Brake Drag
monaro427 wrote:Cheers for that will lube if needed and will do the disc thingee, clean up etc as in one of the other subjects
Rear disc has no bobbins, it's a solid disc. Caliper rebuild!
