Retaining clips on frame for wiring loom
Moderator: VTRDark
TravisZack
Post by TravisZack »
The ones that go around the inside of the frame to hold all the wiring in place. I don't even know if you can remove them without deforming them a bit... they're not in the best shape now so I'm after another set.
Re: Retaining clips on frame for wiring loom
There are two 'bendy' metal clips affixed on the front fairing subframe or there are two plastic ties (with part no.s) > http://www.ronayersmotorcycles.com/fich ... veh=132082
As the bendy metal clips are fixed to the front subframe you could use something like these instead > http://www.ebay.co.uk/itm/Black-10-Pcs- ... OC:GB:3160
TravisZack
Ahh thank you, it's the no.12's that I need on that diagram.
