2x reg recs for sale.
Moderator: VTRDark
Jonesey
Post by Jonesey »
Hey all, I've got 2 r1/r6 reg recs for sale, how about £15 plus post?
CJ.
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
Re: 2x reg recs for sale.
Good price... :thumbup:
Yeti was after one Jonesey, drop him a PM.
shifty123
Post by shifty123 »
Are they the ones that will work for the storms? I'll take one off you please if that's the case. Last thing i need to do :thumbup:
shifty123 wrote:Are they the ones that will work for the storms? I'll take one off you please if that's the case. Last thing i need to do :thumbup:
Yes they will be the one that will fit but...you either chop off the Honda block & re crimp on some spade fittings or you can un-pick the spades from the block. Have a look at the block when you take it off, look in to the end the wires go into. You will see a small plastic tang, stick a small flatblade screw driver in push the tang down & the wire/spade will pull out.
Either disconnect battery or take the fuse out, if the wires touch it will short & blow the fuse...dont ask... :oops:
If when you do this mod if any of the wires show any signs of being burnt, then you'll have to cut them back & re crimp a new spade on.
Before you take out or cut any wires check which sequence they fit into the block & replicate in the new R/R...Don't think it matters with the 3 yellows but the red & green wires must be on the correct pins.
MacV2 wrote:Before you take out or cut any wires check which sequence they fit into the block & replicate in the new R/R...Don't think it matters with the 3 yellows but the red & green wires must be on the correct pins.
A very good point Mac, as the live (+) terminal on the R1 and R6 rectifiers are opposite to the original Firestorm item, so take note or you'll be blowing the main fuse :)
