rear bulb options
thomas111
rear bulb options
Post by thomas111 »
Ok been in the garage putting my new led side light bulb I got from damien in Holland now noticed my rear side light bulbs not working checked stupid looking bulbs yip side light element broke on the 2 so what other bulb options do we have is it a case of changing rear light any help thanks
Re: rear bulb options
Halfords do the standard twin element rear bulb for a couple of quid.
http://www.halfords.com/motoring/bulbs- ... r-bulb-x-1
If using LED have you fitted a resistor?
thomas111
Post by thomas111 »
Hi Wicky no I was just thinking because I fitted the new side light that just replaces the stock bulb that damien makes I thought with these being the bigger capless bulb I would get away with the same idea thanks for the link on these I seen these and would these work
http://pages.ebay.com/link/?nav=item.vi ... 17&alt=web
Without an additional resistor in the circuit you'll save money by using conventional bulbs, rather than buying & plugging in fancy LEDs.
Even though it's for LED indicator bulbs this explains the role of resistor and why its needed > http://www.ebay.co.uk/gds/Load-resistor ... 226/g.html
thomas111
Post by thomas111 »
Thanks wicky yea will just order normal bulbs
