refurbished starter motor for £75 includes shipping within the mainland uk
the refurbishment includes the unit being fully disassembled all the relevant parts are then put through an heated ultrasonic cleaning, any broken or worn parts will be replaced.
the outer casing is then prepped and sprayed with an acid etch primer, followed by two coats of silver paint and two more coats clear satin lacquer to guard against corrosion.
please believe me when I say this isn't a money making scheme, with the time it takes and the cost of tools and replacement parts, I wouldn't consider it worth my time, but I enjoy making use of old parts and making them work again, if it helps fellow bikers and it's good for the planet that's an added bonus.
it is worth noting that the mitsuba sm-13 starter motor also fits the sp1 and sp2, super blackbird, x-11, xl1000v varadero, 900 hornet, and fireblades up to 2003.
the cheapest pattern part/new starter I can find online is over £100, and personally I don't like these Chinese copies.
so if you know of a friend in need of this service, feel free to give them my details.
I can also supply unpainted refurbished starter motors for £60
all the best
Marty/agent p
